1 - 20 of 31 Posts
Just want to know if anyone knows where i can get a flame throwing exhaust for our 600rr ? ? ? ? If so what kind , where , and how much can i get it for ? ? ? ? ?
* I DONT WANT A FLAME THROWING KIT JUST EXHAUST*
Falme throwing exhaust,,, Ahh I see,,, looking to cook some hotdogs for lunch on them long rides.
Exhuasts don't usually throw flames. With a good fuel injected bike, throwing flames would probably have to be done by spraying fuel in the canister and igniting with a spark, or running the bike really rich and sparking the muffler... I think.
thanks but how can i doe that
You have to hook up a seperate fuel system into the slip on with some type of ignition system. It will kill your packing in the exhaust, it will be a pain in the ass to mount the extra fuel somewhere and IMO it will be really pointless, unless its for show purposes. . .
Where do you find emm?> They sell kits for cars and i'm sure they would work on a bike application.
I'm pretty sure it's illegal (and idiotic) to have exhausts that consistently throw flames.
That being said:
The flame is caused by unburned gases in the ehaust that ignite. Aftermarket flamethrower kits inject some kind of accelerant (fuel) into the exhaust to throw flames. I sincerely doubt that you could get that effect just by switching exhaust. You might be able to increase the chance by removing the catalytic converter, but throwing flames is basically just an indication that your bike is running with an improper A/F ratio (translation: like crap).
If you could get your bike to run pretty rich and either hollow out the cat or remove it, you could probably get flames when slowing down and letting it run through the gears from high rpm's to low rpms. You would also probably have to mave the exhaust have a small leak up toward the header so it would suck small amounts of air in so it would help induce the flames. I had a truck I set up rich and dumped the exhaust underneath. Everytime I would downshift and it would pass the 4k rpm mark it would sorta backfire and it would blow blue flames out until I stopped the truck. It was pretty cool....The only reason I had it running rich was for the NOS. Otherwise I doubt I would do it because you'll be changing plugs all the time.
Overpaid South Pacific Barista overactive ADHD c
try downshifting at hi revs and hit the kill switch off / on really quick.. the fuel goes true but does not spark, so fuel in the exhaust, you also need the bike really hot for this... this is not a good idea i wrecks your sh1t, but it is your sh1t so go nuts and have fun....
my stepbrother's F4i he would shoot fire when it was just turned on in the morning, and in cold start mode or whatever, he would bring it up to redline and cut the throttle. a bunch. this is probably not good for the bike. this also worked better with nothing on the exhaust after the header.
If you really want to cook some dogs just wrap them in foil and stick them in the "trunk" and they will be nicely done when you get where you're going.
This is a joke, right???
:flamethro
MacGyver something up... Attach a lighter by the exhaust so when you crack the throttle so hrad, it ignites. Have a can of hairspray mou.ted somewhere on your tail. Rig up a button that shoots the hairspray at the flame, then POW!!!!!!!! That bitch will be shooting flames for like 10 feet if your goin fast enuf...
I watched a Superbike race on speed over the weekend and I cant remember the rider, but he was on a green kawi, anyway, while entering the corners there were flames coming out of his exhausts.
1 - 20 of 31 Posts
