can anyone help me?
if i put in a flasher relay on my 06 600rr will it also control the dash turn indicators also, because you have to hard wire the 06 600rr will the dash blinker indicators flash at the same rate as the led turn signals or does the dash lights think something is wrong and blink fast
if you are using a flasher relay on LEDs, make sure it is a solid state flasher relay, or you will get fast blink. the more common flasher relays rely on the resistance of the bulb to flash properly, which is why you get fast blink with LEDs
Discussion Starter · #4 ·
ya i was going to order the flasher from customled.com i believe that one will work out for this
