what is involved in order to do this?
looking at the new '04's how the rear tail section is flat black, it looks so much nicer...
does anyone have any pointers on how to make this happen?
i am assuming first have to remove the gloss coat somehow.
thanks!
Yeah, curious if any of you with the 04 red/black could give us the black paint code from under the pillion cover. Thanks!
look on ebay.. got mine for $36 :bounce:
xlblazin,
i'm assuming you're planning on doing this yourself with rattle(spray) cans? you'll need several cans of primer, several cans of krylon semi-flat black, and several cans of krylon crystal clear coat, satin finish. just simply follow the directions on the can.
a tip when using rattle cans, spray in 6" blocks to insure you don't get that "spray can look". also, make sure you shake the can throughly to avoid that orange peal effect... good luck.
