1 - 2 of 2 Posts
Hi I just wired front flush mounts and integrated tail light with turn signals. As you can see my bike was pretty hacked up. Now I got everything working with all the signals however I can't get my left side of flush mount work. When the right side of flush mount has same set up left side just won't work. When I turn the left side signal on, my Guage won'tshow the arrow while my tail signal works perfectly fine. Left side of flush mount just turns off.
No need to start 2 threads about the same problem. My suggestion would be to wire each side as turn signals only and leave the running light wire disconnected to see if that works. If you're certain that it can be wired the way you've connected it then perhaps you've got a bad connection on the left flushmount or one of the resistors is faulty?
1 - 2 of 2 Posts
