1 - 2 of 2 Posts
So I just got my cbr 600rr two days ago and it didn't have front turn signal but came separate were a pair of flush mount turn signals. I know i hooked them up right because both of the lights work on the left turn signal but neither of them work on the right side. Just wondering what I need to check to find out the problem
hmmm so first get a voltage meter, check to make sure the wires are getting voltage,
check the wire condition if they arent, then check the wires into the relay,
you should double check your wiring first as you never know,
I usually go in with the mindset of there is a problem, could have been me could have been here before,
GOOD LUCK!
1 - 2 of 2 Posts
