Hey i installed the front and rear flushmounts...i put the resistors in it to get them to flash normally and it only works when the bike is in a high rev..like if im on the highway and the bike is at like 8-9000 rpm and i change lanes its fine but if im cruising around the side streets it will blink slow once that go to blinking really fast...i was thinking bout adding two more resistors to the front, will that work.
Flasher relay $20, will return flash rate to normal. Plug n play
