1 - 2 of 2 Posts
Hey guys, I have some valved forks, and I was going to check the oil level when I disassembled them to match it on reassembly. I checked it and got 120mm. Spring out, damping rod all the way down. Later on I noticed the screw on my fork oil level tool wasn't set in good and it could have gotten a bad reading. :banghead:
The fluid that I used is a little thicker than stock, so it should use the hydralic bottom out more, and need less than the OEM fluid level of 110mm, right?
I know 120mm is really close just by eyeballing it, but not 100%
If I were you.. I would ring the T man and ask him which oil and level to use.
If you know the name of the person who they were built for and they used them for what your going to use them for and they weighed the same and had the same style etc.. then he might still have the specs for them.
Either way he would be able to give you the best answers to your questions
1 - 2 of 2 Posts
