All-righty-then. I just took my suspension measurements. Yes, I could stand to loose a little. Included current sag measurements thanks to an understanding wife.
Fork Preload = 3.5 turns in from full soft.
Fork Compression = 2 turns out from full closed.
Fork Tension or Rebound = 1/2 turn out from full closed.
Shock Preload = 8/10 (or almost max preload).
Shock Compression = 7 clicks out from full closed.
Shock Rebound = 1 full turn from full closed.
Front static sag = 25mm
Front Rider sag = additional 10mm
Rear static sag = 0
Rear rider sag = 20mm
Yes, I think I could bump up the front preload. Thoughts on this part??
Still, I am under the impression that our forks are dual-rate.
http://www.peterverdonedesigns.com/05fork.htm
I was under the impression that the 07-08 (and 09-10) 600rr has essentially the EXACT same forks as the 05-06's...painted black instead of anodized gold. What springs are in our forks? A dual-rate something like these pictures?
I would like to replace my fork springs with a linear 1.00kg/mm, BUT only if necessary.
Thanks for the info so far.
-PB
