Jack for your motor? It will be easier if you have at least a rear stand (swingarm). There is a stock spacer between your engine and the bolt housing on one side of your bike.
But my right frame slider is not like this one it is the same thant the left one.
Will I need to remove the stock spacer? and is there different kind of hole saw because I go to home depot and they all have big teeth. will it do a great job because the hole saw that i bought was for wood.
I did mine without having to use a jack. Just take out one engine bolt and replace it with the slider bolt, then do the other side.
I wouldn't use a wood holesaw as the teeth are alot more coarse then they are on a bi-metal, or metal bit. It might chip or crack the plastic if you cut too fast, you could probably make it work but I wouldn't chance it.
