Hi
Can you guys recommend a set of frame sliders/crash bungs for an 03 that doesn’t need the fairing to be cut/drilled,I can’t seem to find any!
Thanks
That's because no cut sliders are total crap
I bought no cut ones for my 05. They don't even fit. I wouldn't waste my time with them. Waste of money.
Also, I dropped mine in a parking lot going about 10km/h. Wet leaves, front tire slid sideways.. anyways. My bar ends were the only thing damaged. If you're worried about low speed or stopped drops, I don't really find them worth it.
Bar ends
Shorty levers
Rear axle spools for the stand is all you need IMO
No cut sliders work off an extended bracket.
In a heavy fall/impact,this bracket can actually bend back into the side of the engine and crack the cylinder head.
I would avoid installing them and just use the normal ones that need a hole saw to be used on the fairings.
