I am trying to pull the wheel off to have new tires put on. The rear is off and I have removed all the necessary bolts minus the front 22mm nut holding the front axle in place. I have tried everything, even basically standing on the socket wrench and still absolutely nothing. Please help!
Only loosen the ones on the nut side when you go to loosen it, otherwise you may just spin the whole axle.
But if its not budging at all you may have to try an impact
