1 - 3 of 3 Posts
I am having a problem with adjusting the front brake lever. Whenever i adjust it (spin the little dail) to the setting i want 5 , after a few miles it moves by itself to the 6th position. Has anyone had this problem or know whats happening? It usually happens after ive used the brakes hard, and then when i go to grab the lever its on the 6th.
D
Check that the spring between the two pieces of lever is still attached. If that breaks or falls out, the adjustment knob will be able to turn on it's own.
The spring is still there and it doesnt look broken. It feels like the dail spins easier from 5 to 6 then from any other number for example 3 to 4.
1 - 3 of 3 Posts
