1 - 3 of 3 Posts
so...i put the front stand on this morning...just for curiousity...i turn the front wheel to see its rotation and...the brakes are squelling...it's obvious that the rotors are having a little bit of contact with the pads...
what should i do?
1. change the pads
2. leave it as is...almost 8000 miles.
3. get more help.
- D
That's perfectly normal. The caliper pistons do not retract all the way back in, so there will be a little rubbing between the brake pads and the rotor.
No need to worry about it, unless you hear a metal grinding noise when you apply the brakes. :D
1 - 3 of 3 Posts
