1 - 10 of 10 Posts
I have a stock 03 600rr and ever since I replaced the tires, the front stops real choppy..... I don't think the rotors are warped cause it worked perfect before, and when you barely move the bike, you can hear a rubbing noise but not the complete wheel turn, but part of the turn. What can I do to fix this?
I just took them off the forks and took it to a shop to mount the tire.
Highside,
What do you mean? The rubber spacers...I thought they were the same.
K
did they mount the tire on the rim the right way? reversing the rim doesn't really do anything, but the disks are bedded in differently which may explain your stopping issues.
Take your calipers off and press the pistons apart with a screwdriver or something similar then remount. You might not have equal pressure.
I'll have to check that.....When I brake, it pulse brakes really bad because it stops and goes and stops and goes real quick with me holding the brake down the whole time.
1 - 10 of 10 Posts
