Banned
Guys, got around to getting to the wiring today a bit, and I have two connectors I do not know where or if the plug in to things.
It's the white connector up top and the one hanging down on the frame with the blue tie on it.
Heres a place where I am guessing the blue tie, hoping I am wrong, cause its going to be a pain to reconnect it if it is.
Any help in letting me know what or where I am missing items. Thanks.
there should be a male that comes from the front of the bike on the left side
and hooks up to the white plug and that connector plus the large one in the pic
slid under the left side ram air cover
the male connector for the black plug i believe is in the first pic
check them out and post back up
Banned
Moe
I figured out the white connector, thats the ignition cylinder I had to remove because I never got keys with the bike, so once I get that other one connected, I should be good to go, wiring wise.
Thanks again Moe, I do appreciate the help you've always provided.
Steve
my pleasure man
Yeah the black is to the TPS (throttle position sensor). Its a PITA to plug in there with the airbox on. When you connect a PCIII up you need to maneuver a new connector in there. Glad you got it sorted.
