MotoGP NEWS Guru
Hey y'all
I'm racking my brain on this one. Took the front wheel to replace some things after a lowside (clip ons); I reinstalled everything, got the wheel spacers on right and everything (I think) and went for a ride. Felt weird. Came back, put it back on stands and spun the front tire. Didn't spin freely. Felt like it was dragging on the pads (have Vesrah RJLs). So, I took the calipers off to see if the axle was aligned and spun the wheel again. It spun true. So, I think it's a caliper thing. Thoughts? Pads are virtually brand new. Only about 1.5 hours of track time before I hit the dirt. First time riding since it went down.
Ive always noticed my pads dragging on my rotor, but it got WAY more pronounced recently after I had my front tire replaced. Some drag is normal, but if its prohibitive to your front tire rotation, I would squeeze the pads/pistons back into the cylinders a little, then bleed and get the brake pads to grab the rotor again and see if the problem goes away.
Did you maybe bend your caliper mounts in your low side enough to cause the drag? Or your forks got bent?
That's all I can think of.
MotoGP NEWS Guru
I don't think so. Like I said, without the calipers on there, the wheel spins perfect with no hesitation. In fact, it spins as if there's no friction whatsoever. It keeps going and going. Last night, I cleaned up the calipers and thought maybe I had shoved some gunk into the cylinder when I pushed back the pad installing them. Spun freely last night with the calipers on, so I hope that's the cause, but I haven't pumped the brakes yet. I think it's calling for a brake bleed.
