1 - 9 of 9 Posts
Alright so I had my bike out on the road infront of my house cruising up and down. Bike was running perfectly. Rev'd perfect Idled Perfect Cranked perfect.
I turned it around to go back to my house and it died. Cranked it and it was fine. Popped it into first and it died. Cranked it again and rev'd it into first gear and it took off. Then started jerking like crazy. After awhile of it randomly getting gas then not I gave up.
I know it is something to do with the fuel injection, but I dont know what. Obviously the fuel delivery wasnt staying constant. It felt as though there was air in the lines.
Any ideas?
Has the gas been sitting in the tank all winter? Did you put any stabilizer in it before you put it away?
D
Any modifications to the bike recently? Does it have this issue when sitting still idling?
Emptied all the gas out before I moved. Fresh gas.
Weird question. I just installed rear sets. I was just outside and noticed that when I pop it into first that the bike hesitates to idle.
Could it be that i need to adjust the shifter rod?
A little harder than before. It doesnt pop hard into gear though. I dont know how it would effect the fuel though...
D
It could be an electrical issue instead of a fuel issue. Will the bike idle and rev fine in neutral?
It wasnt yesterday when I tried to cranked it. Today it is perfectly fine. Im gonna try to take it out tomorrow and see what it does. I guess its gotta be electrical then.
1 - 9 of 9 Posts
