1 - 3 of 3 Posts
Need a little more info chief. Is it listed as being a non-OEM replacement for this application or is it just some fuel pump?
If you're not short of time, I'm sure ebay is full of used, working fuel pumps
I assume by 'an aftermarket fuel pump thats not made by honda' you mean knock-offs, if yes they should, they are cheaper replicas, will it work well? first you need to define well, its very unlikely they'll have the same life, and its probable they will under-perform (maybe felt, maybe not), personally i'd rather get used OEM's
1 - 3 of 3 Posts
