1 - 10 of 10 Posts
I rode a 12 o clock wheelie and when I set the wheelie down bike died red-light came on dash. Now when I turn the key on the fuel pump wont kick on? And won't crank
I found your problem..
How long were you doing this "12 O clock wheelie for" Did you slam the front end down? Its may be your tip over sensor.....
If your gonna be doing 12 o'clock wheelies bypass your BAS! As this is probably the cause of your fuel pump problem.
Do a quick search on how to reset your bank angle sensor and all will be good again
I have bypassed the tip over sensor is that different then the bank angle sensor? No didn't slam the wheelie down.
It might be as simple as the killswitch (I HATE Honda for this -.-) or it could be him having the kickstand down while in first trying to start it.
1 - 10 of 10 Posts
