1 - 3 of 3 Posts
OK, I'm going to make this story short. Layed the bike down in grass/gravel. The only problem was that the plastics were scratched. Still a perfect riding bike. Took it to a guy who does body work on cars, not bikes. He stripped, took off the gauge cluster and detached the headlights. Put it all back together and now the fuel injection will not turn on when you turn the bike on. Bike will turn over normally, but it just seem like the motor is not getting any fuel. Tried to push start it too, but to no success.
Please help me out guys. I'm hoping its a simple fix.
You need to have the BAS hooked up ( or bypass it for troubleshooting reasons ONLY )
Before you'll get the bike to start... you need to hear the fuel pump prime. If it doesn't, then you still have some sort of electrical problem.
Probably forgot to plug the BAS back in. very common item to forget. either that or it's upside down if he removed it from the upper.
1 - 3 of 3 Posts
