1 - 2 of 2 Posts
Does anybody know which wires can be used +/- to test the fuel pump wired directly to a battery? Also does anybody have a clue to the fuel PSI?
Fuel pressue at idle speed is:50psi.
Check fuel the pressue at idle speed:1300rpm.
To check for voltage remove the small black connector and test between the Brown + & the Green -.
To see if your pump is firing out enough fuel it should squirt out 6.4 us Oz during a 10 second test.
Hope this helps.
1 - 2 of 2 Posts
