1 - 13 of 13 Posts
Hello I need a little help getting the fuel pump to kick. I just got done replacing my air filter and when I went to fire her up the fuel pump wouldn’t kick. Battery is fine and so are the fuses, switched the three left side relays around and still nothing( no corrosion either) the bike was stunted before I got it so there is no BAS. Just trying to get some feed back on what I need to check/ or test?? thanks:01_thumbu
fuel pump wont prime. HELP!
Better?
Probaby the BAS bypass, or the kill switch. I've been guilty of that one. I sat on the side of the road for an hour trying to push start my bike when it died after I accidently bumped the kill switch. Boy did I feel dumb.
It should be pretty obvious. There will be some kind of shoddy workmanship wiring near the guage cluster/harness. Just look for the wire with tape on it and check it out.
Bas, the plug under the gas tank for the fuel pump came off. White plug by battery not plugged in. blown diode(03-04) Bad fuel pump not common. T
Trip
what does the diode do? I am searching the forum before i ask the same questions. same thing here. my batt is good, test all relays, bypassed the BAS and the kill switch. still no pump action. if I remove the relay and bring power from the batt to the relay leads to the pump it kicks on. I cant think of anything else. anyone got a diagram for an 07?
1 - 13 of 13 Posts
