1 - 9 of 9 Posts
Before I went for a ride today I filled up my tank to just about full. rode fro about 1.5 hrs and then came back home. when I got here I lifted the rear up and as I bent over the bike i smelt fuel. Not burned fuel, but fresh. My question is if this is normal. The bike got hot and I hit the twisties so i tought that it was just overflow but I am not sure. thanks guys!
edit: only smell on right side panel (where the tail and tank meet)
I believe its normal others will confirm my thoughts shortly
K
check under your tank, look at the gasket if it's wet with gasoline, you've got a problem. check also your overflow line and your tank breather line.
if you filled it up there could be vapors coming out of the overflow tube. i have seen gasoline vapors coming out before there on a hot day.
i have the same problem but instead its coming from the front of the bike. right inside that air intake hole it stinks of unburnt fuel. i have a rear stand on but i dont think that should change anything.
K
it could very well be a leaking injector as well. that would make sense that you'd smell it right after riding and not after a while... as unlikely that would be, it's a possibility. there are lots of possibilities.
you're going to have to strip it down. fire it up, and watch the fuel tank and anything it's coneected to.
Fire extinguisher ON STANDBY.
1 - 9 of 9 Posts
