1 - 3 of 3 Posts
... ok i installed a clear alternative integrated tailight on my 07rr .... everythin was working fine till i taped the wires and and put the fairing on i also put on a competetion werkes fender ltd which cums with a led license plate light .... and now wen i put my right turn signal on it blows my fuse for the turn signals the horn and the brake light???????? could it be a loose wiring? please sumone help me>>>>>
Short. Double check the wiring. Did you install resistors for the signals? Here is the wiring for the tag light.
The Clear Alternatives taillight plug will plug into your stock white plug. The connection is tight but it will fit. Make sure you line up the connection before attempting to connect them, they are plastic and can damage easily
White connection:
Black wire on the white plug is ground (negative from your tag light)
Running light/ tag light is white/black wire (positive from your tag light)
Brake light is the yellow/black wire
If you want to attach the tag light to the CA taillight the
Red wire is the running light (Positive from the tag light)
Green wire is the brake light
Black wire is the ground (Black from the tag light)
1 - 3 of 3 Posts
