I tried a search but found nothing. I installed a Knn on my friends R6 the other day and it took 10 minutes. I then went out and bought a Knn for my 06 rr and couldnt figure out how to get the damn gas tank off. Anyone with any help I would greatly appreciate it. I took the seat off and undid two bolts at the bottom then I went to the top two by the neck. From thier when it didnt come off I was trying to get the ram air covers off but it appeared as if I had to take the front upper off!!! Help!!!
Professional smart @ss
there are 2 screws on the side of the tank.. you have to remove the top screw from the mid fairing and you should see it.
Unscrew #28 and the plastic push pin on top of the mid and check on the other side of the same cover for another screw.
I didn't have it on my 05, but I think they have a screw on their 03-04's.
Then you bend it and try to get the tip out of the small groove out.
The hard part is getting it off the tank, I just pull down really hard until it pops out. Keep playing with it, it will eventually come out.
I can do it in about a minute, from doing it so many times.:toothy4:
