21 - 24 of 24 Posts
Discussion Starter #21
Ok. I went through the wiring on the turn signals. Solid light blue and ground running to left turn signal. Solid orange and ground the right turn signal. The light blue and orange are the same wires I have connected to the new perch. The same two wires run to the rear turn signals in the taillight. Flashes on the cluster (dim flash not bright like normal) but no actual flashing on the signals.
I had this same problem recently what I did was disconnect the 3rd eye, the tag light, the tail light, and the gauge cluster turned on the bike (the fuse dident blow) so I plugged in them one by one till it blew, I found my instance the wire for my tag light was Pinched against the frame and there was a hole in the wire causing a short.
what is the 3rd eye you are referring to?
21 - 24 of 24 Posts
