The cluster loses power when key is off, clock resets to 1:00 and the trip gets reset. Help.
you might have loose battery cable check both of them + and -
if battery is ok check the cluster harness itself and make sure its
a tight connection
does it ONLY happen when you turn the key off or will it also do it while you're riding?
I'll check the fuse, thanks. It only happens when the key is turned off.
Ya, it was the fuse. I'm such an idiot!
