1 - 3 of 3 Posts
Got a interesting issue here. I have an 07 cbr 600rr with a turn signal half on, however only when the bike is running. Everything works fine while the bike is off. But when its on the left signal is half on. Meaning i can still use it. But it seems to get a small voltage from somewhere.
Wiring looks ok on the outside but mayne its been pinched somewhere? Or maybe its a relay acting up? First time cbr owner. So i have no idea.
Not sure now about 07s but later models have the turn signals on low all the time as 'running lights.' So your issue may be that other side should be on as well. This could just be that one filament on the two filament bulb is burned out on the other side. Switch bulbs and see.
Tire Wheel Helmet Sky Automotive tire
Discussion Starter · #3 ·
Figured it out. Someone rigged a tst industries license plate light wrong and it introduced a voltage to the line.
1 - 3 of 3 Posts
