1 - 3 of 3 Posts
On Friday, I'm going to a salvage yard to look for a donor engine for our project. I want to hand turn it to make sure the internal mechanicals are sound before I purchase it. I know it may vary according to the year but what is the basic approach to hand turning the engine?
Do I rotate it at the output shaft or magneto drive? somewhere else?
Kind regards.
I would assume its the same for all years
how insightful
there is an inspection cover on the right side of the bike. you need a 17mm socket to remove it.
behind it you'll get access to the crank. you can turn it clockwise using a 14mm socket. you'll also need an extension as it is recessed behind the cover.
1 - 3 of 3 Posts
