I Have A 2005 Honda Cbr600rr My Headlights Were Working The Night Before And When I Turned It On Next Morning The Low Beem And High Beam Did Not Work, I Have Bought New Headlights And Also Checked The Fuse It Is Good And Has Current, Everthing Else Works Like The Signles And Everything Else, Does Anyone Know What Could Be Wrong???
I have heard stories where oils from your hands can affect bulb life. This a possibility, or did you wear gloves? Can't see it happening right away though.
1. check the fuse ( fuse box behind left side middle fairing )
If the fuse is ok then proceed to no 2 on this list
2. check the light bulb socket which is part # 6 in the pic
one of the 2 prongs might be loose and if that is the case buy
a new one form the dealer
