CAN anyone find any proof that mass centralization, and having the engine farther forwards helps eliminate head shake? Thus not needing a steering damper?
i think the proof is in the thought, due to the heavy front end the front wheel doesn't skip the ground as easily.
steering dampeners also helps you in corners with wheel chatter on little bumps amongst other things - no matter where the weight is or where the engine is, a dampener will always help.
I put a damper on after a tank slapper and I love the thing. We have some real bad roads around here and I feel a lot safer. Even though some people said not to get one I'm sure glad I did feels much more stable at high speeds as well. I got a scotts damper real nice you have a wide range of control.
Dampers will help you in certain situations, ape-like grips on the bars when leaned, going through bumps mid-corner and aggressive on the throttle, putting the front down after a wheelie and the front is not straight, exiting a corner pretty aggressively. See most of these things can be cured by being smooth on the throttle and as the 600cc bike is forgiving. On a literbike however with gobs of torque I would say a damper is definitely necessary.
