1 - 20 of 28 Posts
yes i know there are other threads related but i cant find MY answer
ok.so last night i took off the nose fairing and this morning tried to start it and the FI wouldn't even prime..i also noticed the headlights are off..i didnt touch any of the relays on the side..fuses are all good..plugs were all in
Now i hear a lot about this BAS and the pain in the a** it seems to be..even though i unpluged the plug behind the gauges, could the sensor still maulfunction?
I want to hot wire the BAS (but then i dont for safety reasons obviously) but i dont want to do it until im sure its that
also tried the "trouble codes" method but i coudl get any blinks..i held it to the red plug and grounded to the subframe
Some help would be nice!
ok i jus wired the green and red/white wire for tha BAS to bypass it but still nothing..so BAS is good
make sure you gauges are connected and the 2 connectors are connected just under the left (sitting on bike) air duct cover.
those plugs are connected..still no lights or prime
the 2 little plugs under the front brake lever are in(the ones that come out of the control switch box) cuz i did take those out..the two little ones under the clutch are also in
im really lost!!!!! and frustrated
electrical problems arn't my favorite problems on the bike
K
if ALL you did was remove the upper cowl, it's not the BAS. Check the dash connector, and the Headlight relay as well as the two main connectors on the left side under the air duct.
cick your FI fuse, check your other fuses.
I want to be specific on the cowl..by removing it i ment the head lights, gauges, etc..i basically just removed the 2 bolts on the main frame.
but i did chck all the fuses and they are good. ive been pushing the dash connector as much as i can so im sure its in..still i do REdo it as i will ina minute jus cuz im going crazy
Knightslugger i know you know your things..can u list out some possible things i MAY have done to cause this
and to clarify..where is the headlight relay? i saw one between the headlights..is that it or is there one on the left side?
also the two little plugs under the front brake lever...is there a certain plug one must go into or are the both just like grounds? im not sure at all i admit
K
i... ...think... it's behind the headlights... maybe it is on the right ride now that i think about it. hmm.. anyway i don't think it's that. you sure you put your BAS back on correctly? the round end of the sensor is at the bottom, arrow pointing down?
the brake lever lines are just for the brake light switch.
yes i never even removed it..i just took it all off as one piece so i could adjust my lower trip tree and i put it all back on..the only plugs i pulled was the one behind the gauge as well as the two main connectors to the side..all of those were put back together
K
OK. you should be having a problem then. not at all. i've done that myself many many times. you may want to remove it again, (PITA, i know) and inspect all your harnesses and connectors for loose wires. i think one of them are at fault here.
Discussion Starter #11
*SIGH*
ok ima go take it off again and ill let you know what happnes..ill try to repaeat EXACTLY everything i did last night on it and hopefully find a mess up otherwise ill still be scratchin my head
if its a faulty wire, which ones should i pay attention to?
ill try chckin em for resistance
K
wouldn't bother with that. just be on the look out for loose or missing pins and wires.
ok so i took it off ..unplugged it all..plugged it back and put it back..i did make progress tho..the third eye light is back on now..still no prime or hi or low beam tho
which one is that? behind the battery?
K
no, that's the starter relay. the fuel cut off relay is the middle of three relays on the left side of the bike under the mid fairing.
Discussion Starter #17
ok i looked in the worng place..lol..brb
alright its plugged in firm..so now i just dunno what to do
i dont see how the center light "just came on"
wish it wud all just "come on!"
K
i STILL think you've got loose wires in the harnesses.
did you test the relay or at least exchange it with a working one?
i'ma pull the wireing diagram. have a look about the fuel cut off.
Discussion Starter #20
ok ima go chck it all again right now
1 - 20 of 28 Posts
