1 - 13 of 13 Posts
How's it going? I have an 05 600rr..i dropped it a while back, right before the winter and my headlights stopped working..i thought it might have been the upper wiring harness that split or something but i got a new one and the headlight still doesn't work..all my fuses are fine, the actual lights are fine..anyone have any ideas on what else it could be? any help would be appreciated!
underneath the left side ram air cover there is 2 plugs
make sure their connection is tight and secure
rrstunter said:
are you talking about the 2 connections that the upper wiring harness connects to?
yes these 2
I checked the connections a couple of times..still no luck..the bulbs are fine, i put them on my buddies rr and they work fine..still no luck tho..
The only other thing i can think of is the headlight harness
is messed up & has a short in it some where
I Am a Ticket Magnet
you might check the relay as well it is between your headlights... i believe you have to take the front fairing off to get to it. sadly. keep us posted.
Jasper1232 said:
check for corrosion in your plugs. my bike i had a little but i used a wire brush and now it's fine. good luck bro!
umm...this post is over two months old :headscrat
omg!! and we still don't know if his headlights are working!!
1 - 13 of 13 Posts
