1 - 16 of 16 Posts
Hey guys sorry its been so long since iv stopped by alot has been going on but i would appriciate the help here goes....
Alright my headlights one day stoped working they just would not turn on high or lows. the blue light showing the high beams being on was off aswell. now i would shut the bike off and on and they would come on aventually. this lasted for about a month now they dont work period for the last month no anything. i tested the headlight bulbs and they are fine they work with a power source outsid eof the bike. my fuse is fine i changed that too. i had a light tester so i poked around a bit and i found that i have power going into my fuse box leaving my fuse box aswell... i took my high beam low beam switch apart and tested that and i DID NOT seem to have juice up there. leaving my fuse box is a thick black wire and a red one and at the switch i think they are both skinny black ones so i dont know where the wires run from my fuse box to what and then how it goes to my switch or my headlights. sorry for the run on sentences and bad spelling im in a rush ahah if anyone has a wiring diagram for an 05 it would help alot or any ideas please let me know
thanks again guys
also i dont think its anyhtign loose because they worked solid or did not work at all no loose connections.
ok can you go into more detail thats not helping me at all
the headlight relay is between the lights. Do you have a service manual.
On my copy check chapter 20, section 25 - I can't copy it to show you!!
Head lights relay is attached to part # 3 in this picture
got to pull the upper off to get to it
moe how the **** have you been buddy? holy **** long time no see thanks for the diagram if i check the relay what am i looking for and what should i do?
How you been man are you back in FL probably not still in CT i presume
as far as the relay make sure its plugged in solid and the wires are intact
unplug it then plug it back in and see what happens
Discussion Starter #11
alright think im going to pull the bike apart tonight. to get to the relay i have to take the whole front end off right? any walk thrue wouldk be much appriciated im sur ei can figure it out bu it helps to have direction
Randy
Were you able to figure out the pages of the link i sent you
yeah bro it all worked out im just dreading pulling it apart and putting it back together
Its a piece of cake man if you got in a jam just post here man will help you out
alright fellas im going to the liqour store grabbing a 30 pack and getting to it ill keep you updated
alright i ripped it all apart im not 100% sure its the relay but im 90% sure so im going to order the relay for 28.00 bucks and go from there i left the relay harness hanging out of the bike so i can test it easily and if its it ill take everything back apart and reconnect everything if its not it ill bring it to the ******* shop and i hope i dont have to. thanks everyone and moeman thanks for the details brother ill call you and let you know whats up in a couple days when i get the relay
1 - 16 of 16 Posts
