1 - 2 of 2 Posts
(fixed) Headlight won't turn on.
Just purchased a 2005 cbr600rr with a ton of problems and are starting to chip away. First problem I've run into is the previous owner had a wire going from the fuse box on the clutch side of the bike, connecting directly to the headlight bulb. It was connected to the far left 10amp (yellow) fuse. Once the wire was removed the headlight stopped working. Any ideas the proper way to fix this problem?
Did simple research, checked the common "broken solder point in kill switch" spot... Soldered the wire back on. Problem solved.
1 - 2 of 2 Posts
