1 - 8 of 8 Posts
Alright guys im having some problems with my headlights. the wire that goes into the kill switch area keeps coming off causing the headlights to go off. My buddy soldered the wire back on but just 2 days after he did it my lights went off again. We just recently installed HIDs but should have nothing to do with them becasue the wire had came loose before. So my question is what else can i do if the soldering does not hold? this is really annoying and i need some help I think this was a common problem becasue i seen it on the forums before but could not come across the thread.
If it's just coming loose you could try some sort of rubber grommet that tightens down on the wires, so they can't pull/vibrate out. Are they too short, and that's what's causing this?
You need to learn to solder. Heat the tab where the wire is being soldered to and put some solder to it. When the solder melts and spreads out ( not staying is a ball) then its ready. Melt some solder to the wire too. Make sure it absorbs the solder... don't just coat the outside. The put the wire on the tab and the gun on the wire. When it melts and looks smooth, not chunky. Pull the solder gun and hold wire still till it cools.
ya my buddy soldered it for me so idk what he did but i need to do something..
well update guys i took it to my friends dads motorcycle shop and he soldered it for me and guess what not even 10 mins of riding it came off again. He thinks its the HIDs making that wire heat up and come off the solder? i really dont know becasue when we put the HIDs in they where fine for over a month and all of a sudden this wire keeps coming off. So ihe soldered it again and he said if that comes off again we will have to hook that wire up somewhere else so it wont get hot anymore?
well rode the bike today for a little bit back and forth to school then again back and forth to the gfs house and the lights are still working. Im really paranoid about riding at night cause i dont want them to shut off while im driving any suggestions? the guy at the shop thinks its my HID kit that is making that wire heat up and loosen the solder? The HID is the same wattage as stock so i dont understand?
1 - 8 of 8 Posts
