So recently i rearranged the front sub harness to go infront of my lights so there was nothing hanging.. After i did it everything was fine until i went to ride at night. Under 5k rpms the lights are fine. once above 5k, they start to flicker.. i thought i might have not fully put the wires back in and didnt mess with it. then the next day i went to work and when i got out of work my lights would not turn on at all. i got home and checked the fuse and it looks fine... i had another front sub harness laying around so i tried switching it.. nothing.. My highs and lows are both completly off.. and when i hit the highs switch the hi beam indicator light wont turn on either.
Check out the black round socket that houses the bulbs themselves these sockets are known to have electrical shorts at their 2 prongs
If it helps it is an 03. and i tried different bulbs. i used my stock ones and plugged straight into the square power piece and it didnt work either. I read somewhere that a solder wire in the throttle case may have came loose? could that be my issue and cause the hi beam indicator to not work also?
