1 - 20 of 23 Posts
so in the morning my bike starts perfect 04 i have.
but when i ride and the temp goes up to 220 or above and i shut it off and try tu turn it back on it feels as if the battery is dead, and the odometer on the trps on the gague resets. and i need to push start it. but when the bike is rly hot and i leave it out for 20 minutes to cool down to 180 or so it starts as if there is no problem, i checked the battery today at the shop and it is in perfect condition... anyone knows what this could be>?
Either your starter motor is going bad, or you have a bad rectifier.
this odly seems to be the answer to the othe r293847283 threads asking the same thing, so i agree!
Starter.. Same thing happened on my track bike.. The brushes are getting hot and causes hard/no start after the bike is warm. T
got it... :D didnt find anything... so how would i check which one it is?
D
Pull your starter out, clean and rebuild it, and then test it out. Or just buy a new one to test.
:+1:thanks guys :D
i know im annoying probb :D but where is it located on the bike? to take it off and clean it out a bit?
If you have to ask, it's located at your nearest Honda or race shop.
so i take it it is not something that can be done in my garage? :D
D
It is. Just honestly something that shouldn't be done by someone who doesn't know what they're doing.
Discussion Starter #11
i agree, so in the am straight to local shop to c what they can do :D
thanks guys for help i appreciate it
back to this, if it was a startor motor would it have the same problem after beeing connected to a car by jump cables?
Yes. Trust me, I have gone through this. You will hurt your head thinking it's something else. It's the starter. Get a new one or rebuild it.. I spent an entire day going through wiring to see if it could be anything else. Just the starter and it works great ever since. T
thanks man :D im taking the bike to the shop cuz i doubt im able to do anything with it on my own :D
If you have a socket and ratchet with extensions you can do the swap. Very easy.
Discussion Starter #17
actually i just flipped my tank and got lost
so im gonna take the bike to the shop as is with no gastank cover and the remainder of plastics and have them do it asap :D wouldnt rly want to screw something up
No sense of adventure mate... :drunk:
Discussion Starter #19
i dont have tools that i need it i go to homedepot i can do it (i think) anyone got a write up how to take it off and exactly what id need to do?
i just dont want to do anything with out doing some research prior :D
1 - 20 of 23 Posts
