1 - 2 of 2 Posts
Hello.
My 2003 600rr not charge battery, with full charge battery start engine and with time the battery drain. I measure the voltage and with 9000rpm I.have 12.4 volt.
Then I measure altenator the coil between it has 0.1 ohm and with 5000rpm give me 69-70 volt ac.
Is the right results?? Anything else to check? I try to fixed my self. no money :-(
Also check and rectifired with diode test and give 0.46 v.
Thanks for your time :)
I know the '03-'06 models had a lot of issues with the voltage regulator. That is most likely your problem. You should be getting around 14V at 5K RPM.
1 - 2 of 2 Posts
