Never thought I would need to start one of these threads ... but here we are
I just installed a PCV on my 2007 RR and after initial install everything ran great.. since I have a track day in a couple weeks I figured I might as well install the track fairings now.
After all the fairings were installed. I went to start the bike and now the fuel pump is not priming...
What could it be? something I didn't reconnect in the front end after removing the headlights?
Help me out guys - I have never ran into this problem before
Cheers,
Parker
well... while I was waiting for a reply I went out to my garage to take another look... and sure enough on the right side I forgot to re-connect the black plug... I don't know what it is for.. but it definitly has something to do with the fuel pump, because the fuel pump primes now and my bike runs great again.
I feel kinda stupid
mods please delete if you feel necessary
D
First, check the kill switch.
If it's not that, is the BAS plugged in?
All fuses good?
ECU snugly plugged in?
PCV getting power?
Go over all of your connections again and make sure everything is plugged in snugly and correct. If there's an open in any of the FI circuit, the fuel pump relay doesn't send power to the pump.
Edit: Damn you.
Plug plug on the front of the bike? If so, BAS.
^Thanks any ways D
