i currently jsut installed galfer ss lines http://www.motosport.com/motorcycle/product/GALFER-SUPER-BIKE-FRONT-BRAKE-LINE-KIT-BLACK/?catalogId=102758 and now i can't bleed the brakes
i also brought this thing http://www.motosport.com/motorcycle/product/HP-TOOLS-HYDRAULIC-BRAKE-BLEEDER/?catalogId=115385 and i installed the lines and when i put it on the right caliper the fluid moves up a lil with me holding the brakes and the other side nothing even comes out. please help i dont know what to do it feels like theres no pressure
Your links don't work. If you put on new lines it can take a while before you start to build pressure. Pump a couple times, hold lever,crack the bleeder, close bleeder, release lever, repeat. Make sure to keep the reservoir topped up with fluid so it doesn't suck air
1) im not sure your entirely following proper bleeding procedure, but if you are, its possible you have air in the master
to get rid of that, full the master res, and use bungee cords, or zipties to hold the brake lever compressed over night this will hold the valve open and let the air sneak out.
Thanks i'm gonna try that and hopefully it works it jsut sucks that theres a winter storm coming tonight
