1 - 16 of 16 Posts
CAn some one shelp me please.
I jsut installed my fender elminator and now my bike wont start.
Is it the electircs??
Do i not install the singnals again??
Or the light for the plates??
Any help is good thanks
Check your wires make sure they are all connected and corrected the right way.
Ya i they do i checked it all the lights all light up indicators.
THe thing is when i try to start my bike it makes a loud tick tick tick noice
I checked the battery it was above 12 volts.
WHat could it be? Does it have to be earthed?
The sound is more of a Trrrrr Trrrr Trrrr. Its like the bateery is short circuitin gor something.
Hitz eit from z back
make sure your battery connections are tight. All most sounds like the battery is low. Does your gauge cluster keep reseting when you try to start it?
try recharging your battery with a trickle charger if you have one... and then put it back in and try to start your bike again. I bet you if anything it's the battery. And stop whining about the problem until you've tried this.
Discussion Starter #11
Thanks for your guys help i got it started again. Im gonna get the dealer to check it out again i think the battery doesnt hold the load.
Still under warranty.
"Superman dat hoe"
turn the bike on with the ignition switch turned to 'on' also.
get on the left side of your bike and get it off the kickstand.
Lift the kickstand up and start Pushing.
When you get it going as fast as you can just jump on that bike, pull in the clutch, kick it into first, and pop the clutch
The bike should start and then quickly pull in the clutch so you dont stall it like a noob.
Bump starting is easier in 2nd or 3rd.
1 - 16 of 16 Posts
