So I rode into work today (it was a little wet out, not sure if that caused the issue) and went I to leave and my bike wouldn't start.
I think it is the Fuel Injection because the bike isn't priming when I turn it on and the FI light thats suppose to come on for a a few sec's wont come on either.
Anybody have a clue what could be wrong???
I checked he fuses under the left faring and the couple fuses under the seat that I could reach with out tools and they all look good! Not sure if there is a special one to check out?
Now my bike is just sitting at my work and I don't even have a freaking way to get it home!
I would check the fuses with an ohm meter... just to make sure. Then, swap out the engine stop relay with the fan relay, If no help... swap it with the fuel cut relay.
If that doesn't fix it... you're gonna have to do some more checking.
Ok here is an update on the bike... I got the bike home that night and took most of the plastics off and was just un-pluggedstuff and checking if anything was loose or rusty and nothing looked wrong at all. tried to start it a few times and nothing, fiddled a little more and tired and it worked. :icon_lol: Fuel injection kicked on the bike primed and it started like nothing was ever wrong with it.
so comes today... it was raining but not too hard so i took the bike for a spin to get it wet like I did the morning before and it worked fine all day on and turned it on and off multiple times and it ran started perfect every time. decided to re-wire my rear end becasue the kid butchered it so i took it out set it all up perfect and i got the tail light and blinkers back on and i started the bike and tested them right before i put the rear end back on. i put he rear end back on with the bike running and i finish and everything is working perfect so i shut the bike off to clean up the tools and i thought, oohhh it's late, no one out on the rode i'll take it for a spin... tried to start it and NOTHING!!!!:sad3::headscrat:dontknow: WTF is going on here!
also this time the front headlights and blinkers don't work and BOTH rear blinkers are just one just one steady, not blinking even though the switch is off.
well I would take the wires off and re do them, also does your tail light have the resistors on it? that would cause the not flashing, but it does sound electrical
