He guys, I havent been on here in a while but i was wondering if i could jump start the bike with my car (2005 chevy trailblazer) or does my battery have too much amps or whatever compare to the bike. My battery died cuz i wasnt starting the bike regularly and its cold here. thanks
you can do it as long as you keep the car off, then unplug ride above 5k rpms on the highway and let the battery charge up :)
I would suggest just buyin a new one it is possible but you are dealing with 2 totally different electrical systems and voltage u do stand a chance of blowing a gate in a diode or the diode itself. if you do it the be as quick as you can about it
+1 make sure the car is OFF. if done while the car is running you run the risk of causing damage to the bikes electrical system.
