1 - 9 of 9 Posts
Looks like someone did a quick fix on the bottom engine case to the stator I have check and found the oil leak is coming from the end of the stator bolt any tips how to fix this I try rtv black silicone but still leak after I leave the bike seating there for a day you can see one drop of oil
Light Motor vehicle Automotive tire Rim Gas
Jaw Automotive tire Snout Sculpture Art
You could fix it right and replace the cover. Even OEM ones are like $75. Clean everything up real nice and never worry about it again.
Half-assed application of JB Weld on a damaged cover looks to be the problem.
Or you could put paper under it and live with the occasional drop of oil.
JB Weld should be tossed and come nowhere near bike!!! Causes impulsive quick-fixes that always results in problems down line. Such as what you're experiencing now, why repeat same past mistakes which results in same problems over and over again?
1. remove stator-cover
2. remove ALL traces of old gasket and sealants. Use razor blade to cut off (not scrape) to leave surface perfectly flat and smooth. Post photo of what this area looks like cleaned up:
3. get straight-edge (short metal ruler) and line up again edge of stator cover and engine-block to verify you cannot see air through contact edge all 360-degrees around stator-cover and engine. DO NOT proceed past this step until you've confirmed both mating surfaces are perfectly FLAT.
4. get new replacement stator-cover gasket: Amazon - CBR600RR stator cover gasket
5. replace that one odd-ball allen-key bolt with new one that's similar to others. Make sure it has depth of 2.0x diameter, no more, no less. Measure existing bolt and subtract or add length necessary.
6. install new gasket, use torque-wrench to install cover bolts in multiple-passes in criss-cross pattern. This final step is #1 cause of leaking covers, if cover doesn't go on perfectly flat and stays perfectly flat by having same torque on all bolts, it WILL LEAK!!!
Not that bolt, the one on outside that's leaking. Notice how its head doesn't match the others?
You shouldn't need a gasket; there wasn't one from the factory. Hondabond should be fine. Otherwise agreed on replacement. The big difference with Hondabond or RTV is that you're going to tighten to finger-tight, wait a while (directions should be on the packaging), then tighten per step 6, above.
I'm not sure if you should use Hondabomd/RTV around the rubber grommet. Directions say no, but I get a small amount of oil seepage from there.
Agreed, just replace it. Rebuilding a bike now had same issue. JB is trash, never put on a bike.. respect your bike...
1 - 9 of 9 Posts
