1 - 13 of 13 Posts
I am Back In Biznez
went to go for a ride today, and I couldn't take it out of steering lock. we put some lub in the key hole but it did little to nothing.
thanks,
did u try to move the bars alittle? sometimes if its not in the right spot it wont go.
so is ur bike just sitting somewhere?
does the key twist or is it stuck too?
I am Back In Biznez
I can turn the key a little, i turn it and can kind of feel the groove then it wont turn any further.
I am Back In Biznez
huh? no i do what it says, push the key in and push down and try to turn, and no my key is not stuck i can put it and out easly.
i say pull the triple take the lock out and see if you can work on it out of the bike... im sure you have tried some lube in there too.
I am Back In Biznez
it seems to start in the proper "groove" but it goes in a little then something stops it.
I am Back In Biznez
Discussion Starter #11 (Edited)
I could not access the screws, so i'm screwed. I think mostier got in there and rusted it up a lil,any recomendations to free it up.
thanks,
I am Back In Biznez
problem solved, my bro tapped the top of the key w/ a rubber malet while turning it. turns out it wasn't going down far enough.
thanks,
1 - 13 of 13 Posts
