Have been sitting on a 2012 CBR600RR for a couple years and just now had the time to sit down and start putting all the Aftermarket Parts on it.
Hit a problem with the Wiseco fuel management unit! Instructions are not that great, doesn't matter, but I have one extra connector which I can not find a connection for!
Have the four injector connectors connected at the injector by the throttle body.
Have one left over that has the same connection, but single (white) wire on the grey connector and a red/white on the block and we can not find where it would to. My first thought was O2 sensor, but the connections are round to a square hole and I have no idea if I need to modify one of the connectors.
Any assistance would be greatly appreciated!
Jack
337 353-3534
Thanks! My son and I traced that damn harness and could not find another matching connector:(
That was one of my thoughts but he thought he had traced it and the connector was completely different.
Will check again in the morning with fresh eyes! Is it in the open or buried in the throttle body housing? Should be pretty easy to trace but obviously I haven't done that well. It all starts to look the same after a while!!
Thanks,
Jack
It sits on the left hand end of the throttle bodies. Its pretty tight against the frame so its a bit tricky
I have a blue, 3 wire connector on my TBS, and a grey and a black male/female connector left on the Wiseco Harness, NO Match!
All five connectors on my harness were the same except one of the female grey connectors is a single white wire connector. Start to wonder if I have the right harness/controller.
Thanks,
Jack
OK, the connector goes to any injector on the TOP Fuel Rail to control the fuel width injection at full power.
The Wiseco Fuel Management Controler is made by Dobeck, super great guys and will take care of any issues!!
Got it set up, tuned and will take it to the track next weekend. Still waiting for some new rear lights/side blinkers, plate mount, etc.
Jack
