1 - 8 of 8 Posts
I removed my brake lever today and when I put it back on I noticed the lever folder forward towards the healight...Is it normal,or did I brake something???
Another thing,I also removed the passenger pegs and the brake light in the rear doesn't work anymore, neither front or back brake?? loose wire??
There is a dial there with numbers that dictates how far you want to set your lever away from the grips or closer to them
A loose spring there is a spring right behind the rear brake lever reattach the spring
and you will be set
so give these 2 steps a try any issues post back up will help you out :rocker:
I know about the dial,and it is workin right, but the lever folds forward has well as backward (brakin)...
Overpaid South Pacific Barista overactive ADHD c
got a pic, its hard to visualise?
I know exactly what your talking about. Yes the lever is suppose to fold forward also, but not many people know that. It is like that because when you turn that dial you are suppose to push the lever towards the front to relieve any pressure off of it. Watch now that I said that, there are going to be like 100+ riders saying, "whoa I never knew it rocked forward"...lol
+1 learned that one a while ago
Yeah,it's true...it's suposed to fold forward. Saw it at the dealership today too...Not a very know fact that...
About not having brake lights,it was a loose wire...
Make sure you hooked your return spring back up. It connects the brake light switch with the lever. Did you adjust the brake light switch? Make sure the light isn't stuck on instead.
1 - 8 of 8 Posts
