1 - 2 of 2 Posts
2004 cbr600rr 1600 miles, jardine slip on. Just noticed the other day that my right side rear marker light does not work, but the blinker flashes. I switched bulbs with the other side and it wasn't the problem. I just installed the slip on a couple of days ago....I was thinking a wire might be pinched or not plugged in correctly? Anybody have any advice?
Sweeper Warrior
i take it when you say the blinker flashes, you mean the indicator on the dash, right? the problem could be the socket for the bulb. if the tab at the bottom of the socket has a lot of corrosion on it, it won't make good contact. look at the bulb on its bottom. see if it looks a little indented. if it does, the tab inside the socket most likely has build up on it. try cleaning the socket. T.K.
1 - 2 of 2 Posts
