1 - 3 of 3 Posts
installing pcIII stuck on tps removal. how much force does it take?? i'm trying to remove my sensor following the instructions in the sticky but it's not working.... please help..
Use a flat head screwdriver to undo the PIN clip and gently pry it up. It should slide right up and out the back and then you can connect it the the PC. Be carefulwith the screwdriver. It doesn't take much force at all.
1 - 3 of 3 Posts
